[gdal-dev] Add capability to safely link against an external
libtiff (3.X) and a GDAL build with internal libtiff (4.0) support
Antonio Valentino
antonio.valentino at tiscali.it
Mon Jul 4 14:10:51 EDT 2011
Hi Even,
Il 04/07/2011 19:52, Even Rouault ha scritto:
>> Even, all tests i performed (ubuntu 11.04 only) passed successfully so I
>> can confirm that the patch works.
> Great
>> My only concern is that I'm not able to reproduce the crash in cases in
>> which GDAL is built without symbol renaming.
> Hum, did you activate --with-hide-internal-symbols ? I somehow remember that
> it paradoxically helped revealing the duplicate symbol issues.
Yes, I tested the both "hide internal symbols" and no symbol hiding with:
* gdalinfo linked against gdal libtiff libgeotiff
* gdalinfo linked against libtiff libgeotiff gdal
* a simple test program that just open a tif file with GDAL and TIFF API
* gdal_translate linked against libtiff libgeotiff gdal
The last test (the one with gdal_translate) also implies writing a TIFF
file.
None of this tests produced a segfault even if in some cases I get
warnings about linking against the wrong libtiff version (one of the
changes you applied recently if I remember well).
I clearly remember I was on debian when a experimented the problem some
time ago even if I don't understand why this should make any difference
if I build GDAL with the same compilation flags.
I'm going to do some test with Julien's programs tonight.
regards
Antonio Valentino
