[gdal-dev] Re: [gdal-java-1.8.0]TransformPoint() - different values
for same inputs, why?
mett
mettbest at gmail.com
Wed Jul 6 16:26:46 EDT 2011
Hello,
thank you very much for your reply. For example:
Upper Left = (*258321.25943477*, 655225.28062628)
Lower Left = (*258321.25943477*, 574605.28062628)
here the X value is the same (258321.25943477), so, I would aspect that also
the conversion is the same related to the X value (in fact is a rectangular
image). But I got different value:
Abs: *24.39163021771631*, 66.2996405709653
Abs: *24.24282066963955*, 65.5792295908428
As you can see, I got 24.3916 in the first case and 24.242 in the second
case. Why?!
Thank you again,
Mattia
View this message in context: http://osgeo-org.1803224.n2.nabble.com/gdal-java-1-8-0-TransformPoint-different-values-for-same-inputs-why-tp6555787p6555890.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
