[gdal-dev] Re: [gdal-java-1.8.0]TransformPoint() - different values
for same inputs, why?
mett
mettbest at gmail.com
Wed Jul 6 17:35:06 EDT 2011
Jean-Claude Repetto wrote:
> On 07/06/11 22:54, mett wrote:
> I think your results are correct, because PROJ.4 gives exactly the same
> ones :
> proj -I -f "%.12f" +proj=lcc +lat_1=64.25 +lat_2=65.75 +lat_0=65
> +lon_0=-19 +x_0=500000 +y_0=500000 +datum=WGS84 +units=m +no_defs
> 258321.25943477 655225.28062628
> -24.391630217716 66.299640570965
> 258321.25943477 574605.28062628
> -24.242820669640 65.579229590843
> Jean-Claude
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Thank you again.
Just to close definitely this discussion, do you think the following steps
are correct in this case?
- Got the Upper Left corner of the image with
GetGeoTransform(adfGeoTransform)
- Found out the others corners in this way:
double miny = adfGeoTransform[3] + width*adfGeoTransform[4] +
height*adfGeoTransform[5];
double maxx = adfGeoTransform[0] + width*adfGeoTransform[1] +
height*adfGeoTransform[2];
- Convert all these 4 points related to the corners with TransformPoint();
Especially the point where I found the other corners, by moving in the
raster space.
Thank you,
have a nice day
MATT
View this message in context: http://osgeo-org.1803224.n2.nabble.com/gdal-java-1-8-0-TransformPoint-different-values-for-same-inputs-why-tp6555787p6556106.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
