[gdal-dev] Unwanted partial transparency when clipping
Michael Corey
mcorey at cironline.org
Wed Jul 6 18:58:17 EDT 2011
Hi all:
I'm using a shapefile as a clipping mask to cut out the shoreline from
some DOQ files that I have merged together. But when I do the clipping
step, I end up with unwanted semitransparency in the non-clipped areas.
I'm pretty sure the problem is only with my gdalwarp step at the end.
Here's my process:
gdal_merge.py -init "255" -o diablo-combined-center-utm10.tif file file
file file
gdal_translate -outsize 70% 70% diablo-combined-center-utm10.tif
diablo-combined-center-utm10-70pct.tif
ogrinfo -al ./diablo_canyon_detail_clipper.shp
//Extent: (XXXX, YYYY) - (XXXX, YYYY)
gdal_translate -projwin XXXX YYYY XXXX YYYY
diablo-combined-center-utm10-70pct-box.tif
gdalwarp -co COMPRESS=DEFLATE -cutline
diablo-combined-center-utm10-70pct-cutout.tif
Can anyone help?
Thanks!
Michael Corey
