[gdal-dev] Append a shapefile to a postgis table using the GDAL/OGR Python interface
Luke Peterson luke.peterson at gmail.com
Wed Jul 6 19:05:44 EDT 2011
On Wed, Jul 6, 2011 at 5:51 PM, Even Rouault
<even.rouault at mines-paris.org>wrote:
> It is just that CreateLayer() will declare the geometry as being Polygon,
> but
> insert MultiPolygon sometimes. That's one of the caveats with the shapefile
> format/driver that will report a layer as being of type wkbPolygon but can
> return geometries that might actually be POLYGON or MULTIPOLYGON.
> Clearly, CreateLayer() is a simplistic implementation that doesn't have all
> the subtelties and options of ogr2ogr... With ogr2ogr, you would typically
> workaround this by using the -nlt MULTIPOLYGON option that would convert
> polygons to multipolygons before passing them to the PG driver.
Well isn't that embarrassing ... this caveat is the third paragraph of the
ESRI shapefile driver page. Thanks for your time, Even.
I'm looking at the shapefile driver now; out of curiosity, is there a
benefit to having SHPT_POLYGON shapefiles return wkbPolygon instead of
wkbMultiPolygon as their GeomType or SHPT_ARC shapefiles return
wkbLineString instead of wkbMultiLineString? Would having the driver return
the "Multi" geometry flavor instead cause a catastrophic failure somewhere?
Or is it a performance issue?
Is there a discussion thread I could read to catch up on this?
Luke Peterson
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110706/6c996ec3/attachment.html
