[gdal-dev] RPC and DEM = Too many points (441 out of 441) failed to
transform
Goo Creations
goocreations at gmail.com
Fri Jul 8 03:38:46 EDT 2011
I've seen that there are quite a lot of messages on this problem, but none
of them helped. When running the following command:
gdalwarp -rpc raw.tif out.tif
with a raw.tif and raw.rpb file, the image "orthorectifies" correctly. The
moment I run:
gdalwarp -rpc -to RPC_DEM=dem.tif raw.tif out.tif
I get the following error:
ERROR 1: Too many points (441 out of 441) failed to transform,
unable to compute output bounds.
I've attached the info of raw.tif. Does anyone know what went wrong, and is
this beacuse of DEM, or is it another problem?
Thanks
Chris
Driver: GTiff/GeoTIFF
Files: raw.tif
raw.rpb
Size is 9628, 8447
Coordinate System is:
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4326"]]
Origin = (30.913295622484902,-24.802523524387549)
Pixel Size = (0.000067480021901,-0.000067480021901)
Metadata:
AREA_OR_POINT=Area
Image Structure Metadata:
INTERLEAVE=PIXEL
RPC Metadata:
LINE_OFF=4080
SAMP_OFF=4576.5
LAT_OFF=-25.0395787325761
LONG_OFF=31.1554993454694
HEIGHT_OFF=0
LINE_SCALE=3914.5
SAMP_SCALE=4294
LAT_SCALE=1
LONG_SCALE=1
HEIGHT_SCALE=4.5035996273705e+15
LINE_NUM_COEFF=-0.145866801707571 -1.10329711280747 -3.86239597262447
+2.58933660668099e-10 -28.872773220706 +2.68554381444917e-11
+2.66066678274063e-13 +0.233414015098293 -1.76613654297724
+6.43648576886715e-14 +1.49832649397565e-14 -0.206809394779316
+0.550008018810227 +5.15954998919738e-15 +4.01585276272362 +5.22420802294871
-1.73715368640512e-16 +1.01499936423132e-19 -3.38302233536952e-25 +0
LINE_DEN_COEFF=+1 +7.63015898979327 +0.544533603046993 +0
-0.173000384439342 +0 +0 -1.00151575139611 -1.37010848384519 +0 +0
-0.202476730291588 +0.437634611086632 +0 -0.87007813002919
-0.375773326407855 +0 +0 +0 +0
SAMP_NUM_COEFF=-0.231718719424942 +1.76982471507257 -0.14795750431688
-4.73119373784374e-10 +2.13811836283462 -3.85268609241549e-12
-2.35309943560894e-12 +25.3990915415468 +0.254311877067769
-2.89679792247779e-14 -8.37241260945736e-14 -2.08642871782854
-2.73075356366074 -3.49988405044981e-16 +0.172374026544827
-0.0126270588964211 -1.11561975938353e-16 +1.4727767628272e-19
+5.24269370859074e-25 +0
SAMP_DEN_COEFF=+1 +7.29237513919745 +0.620858828859381 +0
+0.081413241118419 +0 +0 -0.640261879817039 -0.844565609956026 +0 +0
+0.357196796854916 +0.0314112080522133 +0 +0.0594674065444518
+0.355916093810033 +0 +0 +0 +0
Corner Coordinates:
Upper Left ( 30.9132956, -24.8025235) ( 30d54'47.86"E, 24d48' 9.08"S)
Lower Left ( 30.9132956, -25.3725273) ( 30d54'47.86"E, 25d22'21.10"S)
Upper Right ( 31.5629933, -24.8025235) ( 31d33'46.78"E, 24d48' 9.08"S)
Lower Right ( 31.5629933, -25.3725273) ( 31d33'46.78"E, 25d22'21.10"S)
Center ( 31.2381444, -25.0875254) ( 31d14'17.32"E, 25d 5'15.09"S)
Band 1 Block=9628x1 Type=UInt16, ColorInterp=Gray
Band 2 Block=9628x1 Type=UInt16, ColorInterp=Undefined
Band 3 Block=9628x1 Type=UInt16, ColorInterp=Undefined
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110708/9802f160/attachment-0001.html
