[gdal-dev] gdalnumeric problems with Python 3.2 Windows 7 64 bit
Even Rouault
even.rouault at mines-paris.org
Mon Jul 11 14:47:43 EDT 2011
Le lundi 11 juillet 2011 20:40:56, Isaac Gerg a écrit :
> Hmmm.. I just downloaded numpy from here:
> http://www.lfd.uci.edu/~gohlke/pythonlibs/ the 64bit windows one without
> MKL.
> I installed it successfully and then reran the code. Same error. Any
> ideas?
Yes, as I said in my previous answer, you need numpy at your side, but that's
not enough. The GDAL python bindings need to be rebuilt against a python with
numpy installed. So some extra work would be needed on Tamas side.
