[gdal-dev] gdalnumeric problems with Python 3.2 Windows 7 64 bit
Tamas Szekeres szekerest at gmail.com
Mon Jul 11 16:13:08 EDT 2011
Isaac,
I've took a chance to install the numpy-amd64 packages from the site you
mentioned. If the things are going well the tomorrow builds will contain the
numpy enabled gdal win64 packages.
I should however mention that I have some negative experiences with the
numpy enabled GDAL (WIN64) packages since the GDAL python tests were
crashing with this option, when I was trying to include this this last time.
So in case if the tests are not working well, I must revert this addition
and remove numpy from the Win64 setup. (The Win32 GDALpackages already
contain numpy at http://www.gisinternals.com/sdk)
Best regards,
Tamas
2011/7/11 Isaac Gerg <isaac.gerg at gergltd.com>
> Im not sure I understood your original message.  In any case, I have it
> working now though I used a different GDAL build than the one down by Tamas.
> I uninstalled Tamas' build (had to delete a few files in the site-packages
> directory) and then install the GDAL libs from here:
> http://www.lfd.uci.edu/~gohlke/pythonlibs/
> GDAL-1.8.1.win-amd64-py3.2.‌exe<http://www.lfd.uci.edu/%7Egohlke/pythonlibs/>
>   [6.6 MB]  [Python 3.2]  [64 bit]  [Jul 08, 2011]
> My code now works!
> Isaac
> On Mon, Jul 11, 2011 at 2:47 PM, Even Rouault <
> even.rouault at mines-paris.org> wrote:
>> Le lundi 11 juillet 2011 20:40:56, Isaac Gerg a écrit :
>> > Hmmm.. I just downloaded numpy from here:
>> > http://www.lfd.uci.edu/~gohlke/pythonlibs/ the 64bit windows one
>> without
>> > MKL.
>> > I installed it successfully and then reran the code.  Same error.  Any
>> > ideas?
>> Yes, as I said in my previous answer, you need numpy at your side, but
>> that's
>> not enough. The GDAL python bindings need to be rebuilt against a python
>> with
>> numpy installed. So some extra work would be needed on Tamas side.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110711/b744f76a/attachment.html
