[gdal-dev] Off topic. About GNU GPL; LGPL; MIT; etc license types.
Antonio P. aperezcarro at yahoo.es
Fri Jul 15 03:06:54 EDT 2011
I'd want to know your opinion, by apologising for this out-of-the-list question.
I dont understand if I can or not use third soft components I'd want to add to my commercial application.
I read and read and read GNU and GPL (are the same?) and LGPL, BSD; MIT ...  and I have not any conclusion (I'm very confused)
Starting at the point my appplication are going to be commercial, what can and cannot I do whith the 'free' licenses types ?
What about my own development ? It can exist two uses :
1.- I use third component (exe, lib + source code or full source code)
2.- I use full source code and I have modified some parts.
The check list is then :
            Use exe/dll     Full source code    Modified source code
GPL
LGPL
FOSS
MIT
BSD
And the answer for each item :
- Yes: You can use totally free.
- No1: You have to redistribute your whole own software
- No2: You have to redistribute only the modified original source code
And whats about the obligation to show copyright ?
- Yes : You have to show a GNU/LGPL/etc copyright text.
- No1 : You only have to inform that you use a third component by its name.
- No2:  You have not to show no copyright neither references.
Can anybody fill the list ? Thanks
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110715/d1bdb2b8/attachment.html
