[gdal-dev] build error from svn
Even Rouault even.rouault at mines-paris.org
Sat Jul 16 10:06:36 EDT 2011
Selon David Burken <dburken at comcast.net>:
Dave,
I presume you build GDAL against external libgeotiff, and not internal
libgeotiff. In any case, it is weird because cpl_serv.h should be installed when
installing libgeotiff (I've just verified it with libgeotiff from svn). So I
presume the include paths in the GDAL compilation line might miss a directory ?
Can you give more elements ?
> Hi Frank, all,
> Just fyi, getting build error from svn.  Looks like cpl_serv.h is gone
> now.  See below for minor patch.
> Take care,
> Dave
> $ svn update
> At revision 22725.
> gt_wkt_srs.cpp:33:22: fatal error: cpl_serv.h: No such file or directory
> compilation terminated.
> make[1]: *** [../o/gt_wkt_srs.lo] Error 1
> make[1]: Leaving directory `/home/work/osgeo/gdal/frmts/gtiff'
> make: *** [gtiff-install-obj] Error 2
> Compilation exited abnormally with code 2 at Fri Jul 15 15:06:55
> Patch:
> svn diff frmts/gtiff/gt_wkt_srs.cpp
> Index: frmts/gtiff/gt_wkt_srs.cpp
> --- frmts/gtiff/gt_wkt_srs.cpp    (revision 22725)
> +++ frmts/gtiff/gt_wkt_srs.cpp    (working copy)
> @@ -30,7 +30,9 @@
>    * DEALINGS IN THE SOFTWARE.
> -#include "cpl_serv.h"
> +// #include "cpl_serv.h"
> + #include "cpl_csv.h"
>   #include "geo_tiffp.h"
>   #define CPL_ERROR_H_INCLUDED
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
