[gdal-dev] GDAL unable to recognize large GRC file
Chaitanya kumar CH
chaitanya.ch at gmail.com
Sun Jul 17 04:03:33 EDT 2011
jt,
The .tab file is only used for the projection info.
Were you able to open the file with any other application?
Please check for any extra error messages with the CPL_DEBUG environment
variable set to ON.
On Sun, Jul 17, 2011 at 3:10 AM, jt2000 <thakkar at nexgenwireless.com> wrote:
> I have a large (>500MB) GRC file that is not being read by GDAL correctly.
> *[me at server data]$ gdalinfo filename.grc
> ERROR 4: `filename.grc' not recognised as a supported file format.
> gdalinfo failed - unable to open 'filename.grc'.*
> Is this due to the size? I have other 200MB files that work fine.
> The accompanying Mapinfo TAB file shows the following.
> !table
> !version 300
> !charset Neutral
> Definition Table
> File "filename.grc"
> Type "RASTER"
> (280380.000000,3512760.000000) (0,0) Label "Pt 1",
> (1057470.000000,2824500.000000) (25903,22942) Label "Pt 2",
> (280380.000000,2824500.000000) (0,22942) Label "Pt 3"
> CoordSys Earth Projection 8,74,"m",-99,0,0.9996,500000,0
> ReadOnly
> begin_metadata
> "\Vm\Grid" = "Character"
> "\IsReadOnly" = "FALSE"
> end_metadata
> http://osgeo-org.1803224.n2.nabble.com/GDAL-unable-to-recognize-large-GRC-file-tp6590399p6590399.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110717/7d9e8182/attachment.html
