[gdal-dev] ASCII file to AAIG format
Zoltan Szecsei
zoltans at geograph.co.za
Mon Jul 18 11:43:38 EDT 2011
Probably, but choosing src_datasource is the unanswered part...
ie:
is there a possibility where you can specify columns for eastings &
northings, and not just height?
or does anyone know of an srs_datasource that I can restructure my file
to, that does not make me do the row/column ordering, nor the check for
empty cells?
Thanks for the pointer though, Kyle.
Regards,
Zoltan
On 2011/07/18 17:13, Kyle Shannon wrote:
> Zoltan,
> Perhaps the utility gdal_grid would suit your needs, see:
> http://gdal.org/gdal_grid.html
> * Kyle Shannon
> * ksshannon at gmail.com <mailto:ksshannon at gmail.com>
> On Mon, Jul 18, 2011 at 08:04, Zoltan Szecsei <zoltans at geograph.co.za
> <mailto:zoltans at geograph.co.za>> wrote:
> Hi,
> I have an ASCII file of DEM points that need to be converted into
> AAIG format, so I'm hoping gdal (_translate?) will do the trick
> I do not want to rely on the fact that my DEM is column/row
> ordered, nor that it is "exactly" 2m spaced.
> Is there some free-format ASCII that gdal can read, or does anyone
> know which of the formats read by GDAL won't need to be "ordered"
> or "exact".
> I'm hoping GDAL will take the pain out of ordering my DEM, and
> creating NODATA for missing cell values.
> My file looks like this: (Easting, Northing, height, type)
> 570433.84 201262.28 73.65 MPoint
> 570433.84 201260.28 73.72 MPoint
> 570433.84 201258.28 73.79 MPoint
> 570433.84 201256.28 73.86 MPoint
> 570433.84 201254.28 73.89 MPoint
> 570433.84 201252.28 74.02 MPoint
> 570433.84 201250.28 74.16 MPoint
> Thanks in advance,
> Zoltan
> Zoltan Szecsei PrGISc [PGP0031]
> Geograph (Pty) Ltd.
> P.O. Box 7, Muizenberg 7950, South Africa.
> 65 Main Road, Muizenberg 7945
> Western Cape, South Africa.
> 34° 6'16.35"S 18°28'5.62"E
> Tel: +27-21-7884897 <tel:%2B27-21-7884897> Mobile: +27-83-6004028
> <tel:%2B27-83-6004028>
> Fax: +27-86-6115323 <tel:%2B27-86-6115323> www.geograph.co.za
> <http://www.geograph.co.za>
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
Geograph (Pty) Ltd.
Tel: +27-21-7884897 Mobile: +27-83-6004028
Fax: +27-86-6115323 www.geograph.co.za
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110718/eb90609e/attachment-0001.html
