[gdal-dev] ogr2ogr: create a new shapefile with some math
canduc17
candini at meeo.it
Tue Jul 19 05:54:57 EDT 2011
Hi everyone. I have a shape file with the following characteristics:
INFO: Open of `faggete.shp'
using driver `ESRI Shapefile' successful.
Layer name: faggete
Geometry: Polygon
Feature Count: 833
Extent: (341942.975384, 4732949.828158) - (365163.422399, 4773205.622984)
Layer SRS WKT:
(unknown)
FID_fagget: Integer (9.0)
SUP_HA: Real (19.15)
STRINGA: String (11.0)
TF: String (11.0)
CV: String (11.0)
AX: String (11.0)
DE: String (11.0)
INR: String (11.0)
P: String (11.0)
TIPIFORE: String (11.0)
INT: String (11.0)
ATTRIBUTI: String (25.0)
COD_UNIV: String (50.0)
area_ha: Real (19.9)
FID_comuni: Integer (9.0)
NOME_COM: String (50.0)
NumHa: Real (19.11)
VolHa: Real (19.11)
Y_planted: Real (19.11)
Eta: Real (19.11)
Ws: Real (19.11)
Biomassa_e: Real (19.11)
Wr: Real (19.11)
Wf: Real (19.11)
I need to create a new vector file applying mathematical operations to some
field.
For example, let's say I have to double up every value of NumHa and sum this
result to every value of VolHa.
And I have to insert these new values (for NumHa and VolHa) inside the new
vector.
How can I achieve this?
Is that possible with ogr2ogr?
Thanks in advance...
View this message in context: http://osgeo-org.1803224.n2.nabble.com/ogr2ogr-create-a-new-shapefile-with-some-math-tp6598180p6598180.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
