[gdal-dev] Fw: How to get TerraSAR-X TSX Driver all metadata
Antonio Valentino antonio.valentino at tiscali.it
Wed Jul 20 08:42:23 EDT 2011
Data: Wed, 20 Jul 2011 09:05:06 +0000
Da: ËÎÒ«öÎ <rsyaoxin at hotmail.com>
A: °²¶«Äá°Â <antonio.valentino at tiscali.it>
Oggetto: RE: How to get TerraSAR-X TSX Driver all metadata
Yes,I agree.Thank you.
 > Date: Wed, 20 Jul 2011 10:06:24 +0200
> From: antonio.valentino at tiscali.it
> To: RSyaoxin at hotmail.com
> Subject: Re: How to get TerraSAR-X TSX Driver all metadata
> Hi RSyaoxin,
> Il giorno Wed, 20 Jul 2011 00:23:15 -0700
> RSyaoxin at hotmail.com ha scritto:
> > Hi,Antonio
> >        I need to calibrate TerraSAR-X TSX driver data,but I found
> > that GDAL can only extract some metadata of TerraSAR-X TSX driver
> > data,not extract all the metadata and gcps,for
> > example,calibrationConstant.However,these information is very
> > important.How should I do?Do you have any good idea?
> [CUT]
> sorry I have no access to TSX data at the moment so I can't help you.
> As far a I know TSX products include XML files that store all possible
> metadata so it should be not to hard to retrieve all info you need
> with a little bit of XML parsing.
> Regarding possible improvements to the TSX/GDAL driver I will try to
> retrieve some TSX product to make some test but I can't promise
> anything.
> Anyway I would appreciate a lot if you could file a ticket on
> http://trac.osgeo.org/gdal
> with your feature request.
> RSyaoxin, if you agree I would like to forward this message to the
> GDAL mailing list so that also other users can take advantage form
> this discussion.
> Best regards
> Antonio Valentino
Antonio Valentino
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110720/ebfcc2b5/Originalhtmlpart.html
