[gdal-dev] RE: GDAL unable to recognize large GRC file
jt2000
thakkar at nexgenwireless.com
Thu Jul 21 00:37:05 EDT 2011
I would like to however, it’s a customer file and we’re bound by contract to
keep it confidential.
I can send you hex dump of the header if you’d like. Or let me know any
other way I can help.
John
[mailto:ml-node+6605364-1746864975-340285 at n2.nabble.com]
Sent: Wednesday, July 20, 2011 11:11 PM
To: jt2000
Subject: Re: GDAL unable to recognize large GRC file
John,
Can you provide me the failing file? You can send a link to me alone.
On Thu, Jul 21, 2011 at 4:24 AM, jt2000 <[hidden email]> wrote:
Yes, I'm able to open the raster file in mapinfo.
Turning on the CPL_DEBUG env variable produces the following. Â It dosn't
seem to help much.
Are there any other methods I can debug this?
The file is about 580MB. Â Is there a limitation on # of pixels?
ERROR 4: `filename.grc' not recognised as a supported file format.
gdalinfo failed - unable to open 'filename.grc'.
GDAL: GDALDeregister_GTiff() called.
GDAL: In GDALDestroy - unloading GDAL shared library.
View this message in context:
http://osgeo-org.1803224.n2.nabble.com/GDAL-unable-to-recognize-large-GRC-fi
le-tp6590399p6604781.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
gdal-dev mailing list
[hidden email]
http://lists.osgeo.org/mailman/listinfo/gdal-dev
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
[hidden email]
_____
If you reply to this email, your message will be added to the discussion
below:
le-tp6590399p6605364.html
To unsubscribe from GDAL unable to recognize large GRC file, click here
<http://osgeo-org.1803224.n2.nabble.com/template/NamlServlet.jtp?macro=unsub
scribe_by_code&node=6590399&code=dGhha2thckBuZXhnZW53aXJlbGVzcy5jb218NjU5MDM
5OXw3MTAwMjk0OTg=> .
View this message in context: http://osgeo-org.1803224.n2.nabble.com/GDAL-unable-to-recognize-large-GRC-file-tp6590399p6605407.html
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110720/9c0e06a0/attachment.html
