[gdal-dev] Re: Draw map in Visual C++
Chaitanya kumar CH
chaitanya.ch at gmail.com
Sat Jul 23 08:42:35 EDT 2011
Mark,
You should be able to display an image by filling in a BitMap kind of object
using GDALRasterIO.
On Sat, Jul 23, 2011 at 12:40 PM, mark <mark024 at hotmail.com> wrote:
> Thank you Brian for you reply .
> As you said , gdal is for read / write data.
> So do you know some libraries that allows me to draw maps in my
> application.
> I see many standalone open applications, like OpenEV, but it is not my case
> I am using C++.
> Thanks in advance
> http://osgeo-org.1803224.n2.nabble.com/Draw-map-in-Visual-C-tp6611483p6613079.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110723/873f02af/attachment.html
