[gdal-dev] GML3 wrong result for some kind of fields
Andrea Peri
aperi2007 at gmail.com
Sun Jul 24 06:20:38 EDT 2011
I notice that the GML driver wrong to understand some kind of field.
for example:
I have this tags:
<element>
<id>1</id>
<code>010206</code>
</element>
<element>
<id>2</id>
<code>100206</code>
</element>
the GML driver parsing this tags intepret they as integer so in the
shapefile result
they are translate in
id (integer), code (integer)
1, 10206
2, 100206
this is a bad situation for me because the values in code field is a
block-code to fixed lenght (6 characters).
And after the conversion in shapefile is not possible to join with tables
where there is the values (text) 010206, 100206
I see the GML driver create a .gfs field where it has the description of
these fileds,
I could change it, but unfortunately I have many files and to change all the
gfs is a huge work.
I think perhaps a good solution should be to use a config parameter to
overlap the description in the gfs files.
So I could manually write a GFS file usable for all the files GML I need to
translate in shapefile/postgis.
But I don't know if the gfs file do something else or only the description
of every field.
thx,
Andrea Peri
qwerty àèìòù
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110724/3da01e37/attachment.html
