[gdal-dev] Modis L1B SWATH: georef problem hdf to geotiff
Nikolaos Hatzopoulos nhatzop at gmail.com
Tue Jul 26 12:38:16 EDT 2011
cool!
does it works with 150 files?
--Nikos
On Tue, Jul 26, 2011 at 9:17 AM, Brian Case <rush at winkey.org> wrote:
> Nikolaos
> I have warped modis with swath2grid and mosaicked it with mapserver, I
> have not seen that issue.
> also you don't need to use a vrt to mosaic, this can be done with one
> gdalwarp call.
> gdalwarp file1 file2 file3 outfile
> Brian
> On Mon, 2011-07-25 at 17:20 -0700, Nikolaos Hatzopoulos wrote:
> > It seems interesting I'll keep a note on this :)
> > The question is how you can build a VRT mosaic directly from MODIS hdf
> > files, because
> > the problem is that you have to mosaic first and after that to
> > transform them to the
> > EPSG:4326 projection. If you transform them first and mosaic them
> > after you might have
> > white lines.
> > --Nikos
> > 2011/7/25 Brian Case <rush at winkey.org>
> >         anna, Nikolaos,
> >         after much experimentation I found something that seems to
> >         work.
> >         gdalwarp --config GEOL_AS_GCPS FULL \
> >                 -tps -geoloc -t_srs EPSG:4326 \
> >                 -te -119.88004906118 13.5092548294379 \
> >                 -92.6036641645677 34.7070050511582 \
> HDF4_EOS:EOS_SWATH:"MOD02HKM.A2011169.1750.005.NRT.hdf":MODIS_SWATH_Type_L1B:EV_500_RefSB
> \ MOD02HKM.A2011169.1750.005.NRT.tif
> >         note i tried to escape the newlines to make it easy to read
> >         but the
> >         email may mess that up.
> >         there is about 2.7 million gcp's in a normal 5min modis swath
> >         file, by
> >         default gdal only reads every 10th row and column of gcp's
> >         this is not
> >         enough to handle the bowtie effect.
> >         Brian
> >         On Tue, 2011-01-18 at 16:33 -0800, Nikolaos Hatzopoulos wrote:
> >         > You are right, I notice that there isn't any difference from
> >         the
> >         > band_1.tiff and band_1_warp.tiff
> >         > --Nikos Hatzopoulos
> >         > On Mon, Jan 17, 2011 at 8:15 AM, anna auge <annaauge at web.de>
> >         wrote:
> >         >         Hi all,
> >         >         I am trying to convert modis level 1B data (type
> >         SWATH) to
> >         >         geotiff following these steps.
> >         >         1) Examining the HDF
> >         >         gdalinfo d:\modis\1b
> >         >         \MOD021KM.A2011008.0850.005.2011008195744.hdf
> >         >         gdalinfo HDF4_EOS:EOS_SWATH:"d:\modis\1b
> \MOD021KM.A2011008.0850.005.2011008195744.hdf":MODIS_SWATH_Type_L1B:EV_1KM_RefSB
> >         >         2) Extracting the 1. band of the subdataset
> >         >         gdal_translate -of GTiff -b 1 HDF4_EOS:EOS_SWATH:"d:
> >         \modis\1b
> d:\modis\1b\band_1.tiff
> >         >         4) Warping the image to WGS84
> >         >         gdalwarp -t_srs EPSG:4326 d:\modis\1b\band_1.tiff d:
> >         \modis\1b
> >         >         \band_1_warp.tiff
> >         >         The example dataset, which i am using, can be
> >         downloaded here
> ftp://ladsftp.nascom.nasa.gov/allData/5/MOD021KM/2011/008//MOD021KM.A2011008.0850.005.2011008195744.hdf
> >         >         And now to my problem: I get always an certain shift
> http://www.flickr.com/photos/54033867@N00/5363471425/in/photostream/),
> which is avoided if i am using the "Georeference MODIS" option in ENVI (
> http://www.flickr.com/photos/54033867@N00/5364083966/in/photostream/).
> >         >         I also tried a few workarounds, f.g.
> >         http://thread.gmane.org/gmane.comp.gis.gdal.devel/10482, but
> >         >         nothing worked properly.
> >         >         As far as I understand gdal supports Modis L1B
> >         SWATH, so what
> >         >         I am doing wrong? Any help is appreciated.
> >         >         Regards Anna
> >         >         P.S. I am using FWTools 2.4.7 on Windows
> >         >         WEB.DE DSL Doppel-Flat ab 19,99 ¤/mtl.! Jetzt mit
> >         >         gratis Handy-Flat!
> >         >         http://produkte.web.de/go/DSL_Doppel_Flatrate/2
> >         >         _______________________________________________
> >         >         gdal-dev mailing list
> >         >         gdal-dev at lists.osgeo.org
> >         >         http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110726/f0b683b4/attachment.html
