[gdal-dev] create classified PNG from ASCIIGrid
Chaitanya kumar CH chaitanya.ch at gmail.com
Wed Jul 27 01:00:17 EDT 2011
Stephen,
The docs for rgb2pct.py script [1] has an example that shows how to convert
to a paletted image using hand made VRT file.
You can use the "-of PNG" option to set the destination format as png and
the -pct option with your VRT file.
On Wed, Jul 27, 2011 at 2:42 AM, Stephen Crawford <src176 at psu.edu> wrote:
> Hi All,
> I have 60 or so asciiGrids of climate data that I would like to tun into
> PNGs, with the climate values classified by color.  I would like to script
> this process using Python.  Is there a way to do this with GDAL?  Or if not,
> is there any other open source way to do this?
> Thanks,
> Steve
> ______________________________**_________________
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> http://lists.osgeo.org/**mailman/listinfo/gdal-dev<http://lists.osgeo.org/mailman/listinfo/gdal-dev>
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110727/7ae12124/attachment.html
