[gdal-dev] Quick question regarding image translation in Java (I
think)
Mike O'Malley
mike.omalley at nextcentury.com
Thu Jul 28 14:33:46 EDT 2011
Hopefully this is a quick one, I think the answer's so obvious I'm
missing it. I'm trying to use GDAL to create a TIFF copy of a NITF
file. I've downloaded and compiled 1.8.1 (under Windows) and used
gdal_translate from the command line to create the copy. I can view the
new file from IrfanView and everything looks good.
When I try to do this programmatically from Java, however, things
break down. I'm using the Java bindings from 1.7 in case that's an
issue; I've tried a number of things, but haven't recompiled the
bindings yet. My code is:
Dataset ds=gdal.Open(datasetFilename,
gdalconstConstants.GA_ReadOnly);
if (ds == null) {
System.out.println("GDALOpen failed - " +
gdal.GetLastErrorNo());
System.out.println(gdal.GetLastErrorMsg());
gdal.GDALDestroyDriverManager();
System.exit(1);
System.out.println("Image has "+ds.getRasterCount()+"
bands");
Driver driv=gdal.GetDriverByName(saveFormat);
driv.CreateCopy(outFilename+"."+saveFormat,ds);
Which looks about as basic as it gets. The file is created, but it's
slightly shorter than gdal_translate's version of the copy and contains
one color as opposed to the original count of 256 colors. The histogram
of the new image is completely flat. Both images are single-band,
though the gdal_translate copy has 8BPP and the new one has 24BPP. The
dimensions remain unchanged and it's a valid TIFF file, just with bad
pixel data.
This occurs with most of the NITFs in my set. The NITFs are viewable
using FWTools and look good; the TIFFs created by gdal_translate match
them. It's just my Java code that's producing blank images.
Am I missing something obvious?
Thanks,
Mike
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110728/59413756/attachment.html
