[gdal-dev] ogr2ogr projecting from postgis to postgis
Chaitanya kumar CH
chaitanya.ch at gmail.com
Sun Jul 31 01:08:23 EDT 2011
Bryan,
OGR is reading the layer definition of the source. The problem must be when
reading the features.
Run your commands after setting the environment variable CPL_DEBUG to ON.
Report any new messages.
What is the output of ogrinfo with the options -al and -so on the database?
On Sun, Jul 31, 2011 at 6:37 AM, Bryan Hempen <bryanhempen at gmx.de> wrote:
> Hi!
> I have a little trouble figuring out how to use ogr2ogr to read spatial
> data from a postgis table, project it and store it back in the database. I
> do not want to create a shapefile or something like that and load the data
> back into the database again.
> Using ogr2ogr for data other than stored in a PostGIS database works
> perfectly fine, but I can't even export PostGIS data to a shapefile or GML
> (always empty) and I don't know why...
> What worked out well so far is loading the PostGIS data with QGIS, save it
> as a shapefile, THEN project it to another shapefile and finally load the
> shapefile into the database. Yet, as I said before, I would like to directly
> project the data from database to database.
> I know that PostGIS provides a function called st_transform for exactly
> this purpose, but I need to use ogr2ogr.
> Here is the command which does not work so far, hopefully you guys can give
> me some help:
> ogr2ogr -f "PostgreSQL" -s_srs "+proj=longlat +a=3396190 +b=3376200
> +no_defs" -t_srs "+proj=tmerc +lat_0=0 +lon_0=0 +k=0.9996 +x_0=0 +y_0=0
> +a=3396190 +b=3376200 +units=m +no_defs" PG:"dbname='test4' host='localhost'
> port='5432' user='postgres' password='xxx'" PG:"dbname='test3'
> host='localhost' port='5432' user='postgres' password='xxx'" alldata
> Notes:
> - the table containing the geometry column is called alldata
> - the_geom is added with AddGeometryColumns
> - alldata contains some more non-spatial columns
> - I need the results to be stored in the database. In this command above I
> try to store the results in a different database on the same server. The
> database is empty so far. What would be even better is to add an additional
> column in the same database as the original data like the_geom_projected and
> store the projected geometries in there.
> I am using the last FWTools, PostGIS 2.0, PostgreSQL 8.4.
> When I run the command above I get the following message:
> Warning 1: Multi-column primary key in 'raster_columns' detected but not
> supported.
> supported.
> ERROR 1: AddGeometryColumn failed for layer alldata, layer creation has
> failed.
> ERROR 1: Terminating translation prematurely after failed
> translation of layer alldata (use -skipfailures to skip errors)
> I have tried a lot of the examples on the website and some tutorials, but
> nothing worked. Even simple simple exports like
> ogr2ogr "C:\Documents and Settings\user\Deskto
> p\new1.shp" PG:"dbname='test3' host='localhost' port='5432'
> produce an empty shapefile. What am I doing wrong? Thanks for your help.
> Kind regards,
> Bryan
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110731/f48f48b3/attachment-0001.html
