[gdal-dev] How to specify extent of a VRTWarpedDataset in Python?
Anton Korosov
anton.korosov at nersc.no
Wed Jun 1 05:08:59 EDT 2011
Hi!
we are developing software for automatic processing of satellite data
and decided to base it mostly on GDAL-Python bindings. Can I ask you
about options to create Warped VRT datasets in Python?
1. The command
gdalwarp -t_srs '+proj=utm +zone=24 +datum=WGS84' -of VRT -tr 1000 1000
-te -1000000 7000000 2000000 10000000 input.tif output.vrt
creates a VRT file of subclass VRTWarpedDataset. The size, resolution
and spatial reference is specified by the options of that command.
Is there any way I can create such VRTWarpedDataset using GDAL-Python
bindings?
I'm afraid that with the function gdal.AutoCreateWarpedVRT() I can
specify only spatial reference (i.e. UTM Zone) but not raster size and
resolution. Am I right?
Of course I can edit the generated VRT file and adjust RasterXSize,
RasterYSize, GeoTransform and DstGeoTransform manually. But is there any
way to do that programmatically?
2. How can I convert the VRT dataset generated by AutoCreateWarpedVRT
into a string without writing to disk? That's necessary since a VRT from
a MERIS full swath exceeds 6 MB. Also for our applications it would be
much more efficient to edit XML in memory and then to flush to disk with
CreateCopy.
Thanks for support!
Anton
