[gdal-dev] How to specify extent of a VRTWarpedDataset in Python?
Antonio Valentino
antonio.valentino at tiscali.it
Wed Jun 1 07:26:43 EDT 2011
Hi Even, hi Anton,
Il giorno Wed, 01 Jun 2011 11:32:55 +0200
Even Rouault <even.rouault at mines-paris.org> ha scritto:
> Selon Anton Korosov <anton.korosov at nersc.no>:
> > Hi!
> > we are developing software for automatic processing of satellite
> > data and decided to base it mostly on GDAL-Python bindings. Can I
> > ask you about options to create Warped VRT datasets in Python?
> > 1. The command
> > gdalwarp -t_srs '+proj=utm +zone=24 +datum=WGS84' -of VRT -tr 1000
> > 1000 -te -1000000 7000000 2000000 10000000 input.tif output.vrt
> > creates a VRT file of subclass VRTWarpedDataset. The size,
> > resolution and spatial reference is specified by the options of
> > that command. Is there any way I can create such VRTWarpedDataset
> > using GDAL-Python bindings?
> Yes, with Dataset.Create() by specifying a SUBCLASS=VRTWarpedDataset
> creation option. ... But I don't think it will help you much since the
> GDALInitializeWarpedVRT() that is then used by gdalwarp to fill the
> dataset isn't mapped to SWIG.
maybe the gdal.ReprojectImage could help, but I don't have the time to
test it right now.
best regards
Antonio Valentino
