[gdal-dev] How to specify extent of a VRTWarpedDataset in Python?
Antonio Valentino
antonio.valentino at tiscali.it
Thu Jun 2 03:22:37 EDT 2011
Hi Even,
Il 01/06/2011 13:58, Even Rouault ha scritto:
> Selon Antonio Valentino <antonio.valentino at tiscali.it>:
>>> Yes, with Dataset.Create() by specifying a SUBCLASS=VRTWarpedDataset
>>> creation option. ... But I don't think it will help you much since the
>>> GDALInitializeWarpedVRT() that is then used by gdalwarp to fill the
>>> dataset isn't mapped to SWIG.
>> maybe the gdal.ReprojectImage could help, but I don't have the time to
>> test it right now.
> I don't think ReprojectImage() will work when outputing to a VRT dataset.
Thank you for the info.
Just for curiosity, there is a particular reason why
GDALInitializeWarpedVRT has not been exposed to Python or simply no one
got the time to do it?
regards
Antonio Valentino
