[gdal-dev] Python BuildPolygonFromEdges fails near equator
Jerl Simpson
jsimpson at wxtrends.com
Thu Jun 2 07:48:04 EDT 2011
Your blind guess was perfect!!
Thank you, that did it.
Jerl
On Thu, Jun 2, 2011 at 6:43 AM, Even Rouault
<even.rouault at mines-paris.org> wrote:
> Jerl,
> Difficult to say without seing the data and the exact BuildPolygonFromEdges you
> invoke...
> A blind guess would be to increase the value of the tolerance parameter.
> Best regards,
> Even
This communication is privileged and may contain confidential
information. It's intended only for the use of the person or entity
named above. If you are not the intended recipient, do not distribute
or copy this communication. If you have received this communication in
error, please notify the sender immediately and return the original to
the email address above. © Copyright 2011 Weather Trends
International, Inc.
