[gdal-dev] Insert non-standard tag into geotiff header
Chaitanya kumar CH
chaitanya.ch at gmail.com
Sat Jun 4 06:12:46 EDT 2011
marine88,
The default profile of GDAL's GeoTiff driver allows adding custom tags. [1]
You can add tags using the GDALMajorObject::SetMetadataItem() method. [2]
[1]: http://www.gdal.org/frmt_gtiff.html
[2]: http://www.gdal.org/classGDALMajorObject.html
On Sat, Jun 4, 2011 at 1:50 AM, marine88 <holloway.richard at geoeye.com>wrote:
> HI,
> I am new to this and was asked if I could insert a custom tag into the
> geotiff header. I have no clue on how to do this is this even possible?
> http://osgeo-org.1803224.n2.nabble.com/Insert-non-standard-tag-into-geotiff-header-tp6436732p6436732.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110604/b97edb03/attachment.html
