[gdal-dev] Insert non-standard tag into geotiff header
Frank Warmerdam
warmerdam at pobox.com
Mon Jun 6 13:15:30 EDT 2011
On 11-06-03 04:20 PM, marine88 wrote:
> HI,
> I am new to this and was asked if I could insert a custom tag into the
> geotiff header. I have no clue on how to do this is this even possible?
> Thanks for the reply. Is this only in C? Or is there something in C#? Also
> I get the function but...not quite sure how to utlize this, is there some
> tutorial or example code I can go by?
Richard,
The SetMetadataItem() method referenced by Chaitanya is also available
in C. It can be invoked on the dataset as a whole or on a particular
band object. The C function is:
CPLErr GDALSetMetadataItem ( GDALMajorObjectH hObject,
const char * pszName,
const char * pszValue,
const char * pszDomain
http://www.gdal.org/gdal_8h.html#c92aec63371e9e4b0121276406f0bd8d
So you can pass a GDALDatasetH or GDALRasterBandH as "hObject". Yhe
pszDomain should normally be NULL unless you want to set metadata items.
Note that this puts the metadata items all into one custom GDAL tag for
metadata (which will be an XML formatted string with the various metadata
items). There is no mechanism in GDAL to write out an arbitrary new TIFF
tag. If you need to do that you are pretty much reduced to using the
libtiff API.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
