[gdal-dev] HDF5 COSMO-SKYMED metadata problems
Alex Mantaut
alexmantaut at suremptec.com.ar
Tue Jun 7 16:13:36 EDT 2011
Antonio:
Thanks for the swift answer. I've tried to apply the patch to
gdal 1.8 but it fails on the 5º chunk (hdf5dataset.cpp from line 598)
I looked at the code and it seems significantly diffrent (perhaps
this class was modified since the patch was released a year ago?)
Can you release a newer version of the patch please?
Vi ringrazio un'altra volta
2011/6/7 Antonio Valentino <antonio.valentino at tiscali.it>
> Hi Alex,
> Il 07/06/2011 20:13, Alex Mantaut ha scritto:
> > Hi:
> > I'm trying to get georreference information from an HDF5 COSMO-SKYMED
> file.
> > I used HDFView to see the file's metadata and found that in this type of
> > HDF5 files the georreference information is stored in the metadata
> > corresponding to the "root" of the file.
> > The problem is that when i try to use gdalinfo to get the file's
> metadata,
> > it shows the metadata asociated to all the subdatasets included on the
> file,
> > but not the root's metadata...
> > My cuestions: How do i get the metadata asociated to the "root" of the
> file?
> > Is there a better way to get georreference from COSMO-SKYMED HDF5 files?
> > Thanks in advance
> Ticket #2412 [1] has an associated patch that could be useful in your
> case (i.e for retrieving metadata associated to the root group).
> [1] http://trac.osgeo.org/gdal/ticket/2412
> ciao
> Antonio Valentino
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Alex Mantaut
SUR Emprendimientos Tecnológicos
Perú 345 Piso 5to Oficina "B" (C1067AAG)
Ciudad de Buenos Aires, Argentina
Tel. +54 (11) 4342-2976/84
javierurien at suremptec.com.ar
www.suremptec.com
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110607/becfe37d/attachment.html
