[gdal-dev] gdal_translate - ECW format and non-UTM projections
Armin Burger
armin.burger at gmx.net
Wed Jun 8 13:36:35 EDT 2011
Frank, Jean-Claude,
thanks for pointing me to the ECW definitions. My main problem are
currently the missing ETRS89/GRS80 definitions for several pan-European
projections that are missing. Some national projections I need I could
already identify and I will try them. If a projection is missing can I
add it and GDAL will try to use it when reading and creating ECW files?
Regarding the datums I guess I will be limited to the ones available in
this list an understood by the ECW library, right?
Is there a way to update an ECW file adding this type of information via
GDAL API functions? I know there was a Windows GUI tool from ER Mapper
some years a go that could modify some kind of ECW header, but I would
need to run this on at least several 100's of files, so a manual
approach is not feasible. Or do I need to re-create all ECW's and add
the projection options?
I will try to put together a good description for a ticket and then I
will create one.
One funny observation I made for the mentioned case where using the ECW
file via MapServer WMS was not applying a datum shift: I made a quick
test defining the ECW as only source of a virtual image using the
standard projection definition for the VRT image. Using this VRT as
layer data source in Mapserver the datum shift was applied...
Best regards
Armin
On 08/06/2011 17:44, Frank Warmerdam wrote:
> On 11-06-08 11:30 AM, Armin Burger wrote:
>> Jean-Claude
>> I guess it's not only a problem of gdalinfo but of some parts of GDAL
>> in general dealing with the ECW.
>> I made some more tests and when I add the options
>> -co DATUM=WGS84 -co PROJ=NUTM32
>> to the gdal_translate call then gdalinfo identifies the coordinates
>> correctly afterwards, but then of course the whole projection is set
>> to UTM...
>> It seems that the default value entered for DATUM is "RAW" and that
>> seems to cause some of the problems afterwards for GDAL. The problem
>> for me is that I need to insert the correct datum and projection using
>> the syntax of ECW, and I don't know if all available
>> datums/projections used e.g. in Europe are supported, and which syntax
>> to use for the available ones.
>> I found on my Windows installation a file "PcskeyProjDatum.dat" with a
>> few definitions of projection and datum used but this was very limited
>> and covered mainly UTM and NAD. Most European projections and datums
>> were missing in this file.
> Armin,
> GDAL skips with a file data/ecw_cs.wkt that lists many ECW
> projections and datums. Perhaps it will be helpful.
> There are definately problems translating coordinate system
> into the ECW dictionary. A ticket for a particular case
> *might* lead to some improvement but it is an iffy process.
> Part of the problem in the thread mentioned by Jean-Claude
> is that when the coordinate system translation fails GDAL
> also gives up on read the georeferencing transform - or at
> least I think it used to work this way. I think there may
> have been some recent fixes in this regard. If not, a ticket
> might be appropriate.
> Best regards,
>> -------- Original-Nachricht --------
>>> Datum: Wed, 08 Jun 2011 16:27:22 +0200
>>> Von: Jean-Claude Repetto<jrepetto at free.fr>
>>> An: Armin Burger<armin.burger at gmx.net>
>>> CC: gdal-dev at lists.osgeo.org
>>> Betreff: Re: [gdal-dev] gdal_translate - ECW format and non-UTM
>>> projections
>>> Hi,
>>> I think there is a bug in gdalinfo, I already noticed this kind of
>>> problem, for example
>>> <http://osgeo-org.1803224.n2.nabble.com/gdal-dev-corner-coords-in-tif-vs-ecw-td5608144.html>
>>> You should file a bug at<http://trac.osgeo.org/gdal/> .
>>> Jean-Claude
