[gdal-dev] gdalwarp: ERROR 2: Out of memory allocating {number}
byte destination buffer.
Benjamin Welton
benjamin.r.welton at wmich.edu
Wed Jun 8 15:34:19 EDT 2011
Hey Matt,
If i remember correctly osgeo4w is 32bit (its been a while since iv
looked at the osgeo4w binaries however so i may be incorrect). If they
are 32bit and you are setting -wm to 2048 (2GB) you might be having
memory limitation issues (which i believe 2GB virtual memory for x86
executables on windows).
Ben
On 06/08/2011 02:05 PM, Matt Wilkie wrote:
> Hi Folks,
> Can anyone tell me what this error means and how to work around it?
> Win7 x64 command shell
> osgeo4w gdal 1.8
> 13gb ram (~4.7gb free according to Process Explorer)
> 121gb free on the drive (mapped to network)
> 20gb free on drive pointed to by %TEMP%
> There are 26 input files whose size ranges from 110mb to 260mb,
> totalling 5.5gb(ftp://ftp.geomaticsyukon.ca/DEMs/CDED_50k/)
> If I up GDAL_CACHEMAX and -wm to higher value, like 2048, I get the
> error on every single input file instead of just some (I'm still
> waiting for the results of not using those options at all).
> *gdalinfo --version
> *GDAL 1.8.0, released 2011/01/12*
> set .gdopt=*--config GDAL_CACHEMAX 500 -wm 500 --config bigtiff
> if_safer -multi
> *set .input=*..\dem_105E.tif ..\dem_105L.tif ..\dem_105M.tif
> ..\dem_105N.tif ..\dem_106C.tif ..\dem_106D.tif ..\dem_106E.tif
> ..\dem_106L.tif ..\dem_115F.tif ..\dem_115G.tif ..\dem_115H.tif
> ..\dem_115I.tif ..\dem_115J.tif ..\dem_115K.tif ..\dem_115N.tif
> ..\dem_115O.tif ..\dem_115P.tif ..\dem_116A.tif ..\dem_116B.tif
> ..\dem_116C.tif ..\dem_116F.tif ..\dem_116G.tif ..\dem_116H.tif
> ..\dem_116I.tif ..\dem_116J.tif ..\dem_116K.tif
> *gdalwarp %.gdopt% -t_srs EPSG:26907 -r bilinear -tr 30 30 %.input%
> dem.tif*
> Creating output file that is 15662P x 23332L.
> Processing input file ..\dem_105E.tif.
> Using internal nodata values (eg. -3.40282e+038) for image
> ..\dem_105E.tif.
> 0...10...20...30...40...50...60...70...80...90...100 - done./
> /next 7 inputs processed successfully/
> Processing input file ..\dem_115F.tif.
> ..\dem_115F.tif.
> 0...10...20...30...40...50ERROR 2: Out of memory allocating 365425784
> ...60...70..Processing input file ..\dem_115G.tif.
> ..\dem_115G.tif.
> Processing input file ..\dem_115H.tif.
> /Error at 50% on dem_115f.tif, but carries on /
> /then starts a new input, dem_115g.tif, at 70%+/
> /and apparently completes 115f, or is that 115g?/
> /in any case the next tile, dem_115h, is successful: /
> ..\dem_115H.tif.
> /next 2 are successful,
> followed by 13 errors./
> Processing input file ..\dem_116J.tif.
> ..\dem_116J.tif.
> ERROR 2: Out of memory allocating 365425784 byte destination buffer.
> Processing input file ..\dem_116K.tif.
> ..\dem_116K.tif.
