[gdal-dev] HDF5 COSMO-SKYMED metadata problems
Alex Mantaut
alexmantaut at suremptec.com.ar
Wed Jun 8 17:23:59 EDT 2011
Sorry, I accidentalñy pressed the "send" button
Another issue. Does anybody has the COSMO-SKYMED HDF5 format specification
or something that tells how to get the georreference information from those
files?
2011/6/8 Alex Mantaut <alexmantaut at suremptec.com.ar>
> I tried the patch warmerdam posted on the 1.8.0 version an it worked, i can
> see the root metadata now.
> Thanks Antonio Valentino and Frank Warmerdam for the swift correction.
> 2011/6/7 Alex Mantaut <alexmantaut at suremptec.com.ar>
>> Antonio:
>> Thanks for the swift answer. I've tried to apply the patch to
>> gdal 1.8 but it fails on the 5º chunk (hdf5dataset.cpp from line 598)
>> I looked at the code and it seems significantly diffrent
>> (perhaps this class was modified since the patch was released a year ago?)
>> Can you release a newer version of the patch please?
>> Vi ringrazio un'altra volta
>> 2011/6/7 Antonio Valentino <antonio.valentino at tiscali.it>
>>> Hi Alex,
>>> Il 07/06/2011 20:13, Alex Mantaut ha scritto:
>>> > Hi:
>>> > I'm trying to get georreference information from an HDF5 COSMO-SKYMED
>>> file.
>>> > I used HDFView to see the file's metadata and found that in this type
>>> of
>>> > HDF5 files the georreference information is stored in the metadata
>>> > corresponding to the "root" of the file.
>>> > The problem is that when i try to use gdalinfo to get the file's
>>> metadata,
>>> > it shows the metadata asociated to all the subdatasets included on the
>>> file,
>>> > but not the root's metadata...
>>> > My cuestions: How do i get the metadata asociated to the "root" of the
>>> file?
>>> > Is there a better way to get georreference from COSMO-SKYMED HDF5
>>> files?
>>> > Thanks in advance
>>> Ticket #2412 [1] has an associated patch that could be useful in your
>>> case (i.e for retrieving metadata associated to the root group).
>>> [1] http://trac.osgeo.org/gdal/ticket/2412
>>> ciao
>>> Antonio Valentino
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>> Alex Mantaut
>> SUR Emprendimientos Tecnológicos
>> Perú 345 Piso 5to Oficina "B" (C1067AAG)
>> Ciudad de Buenos Aires, Argentina
>> Tel. +54 (11) 4342-2976/84
>> javierurien at suremptec.com.ar
>> www.suremptec.com
> Alex Mantaut
> www.suremptec.com
Alex Mantaut
www.suremptec.com
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110608/5435aea9/attachment.html
