[gdal-dev] Converting from 16 bit to 8 bit images (best practices?)
Jonathan Greenberg greenberg at ucdavis.edu
Wed Jun 8 22:31:09 EDT 2011
Nikos and GDALers:
This is CLOSE to what I'm looking to do, but I'm having a hard time getting
it working properly.  Here's my input dataset gdalinfo dump:
Driver: ENVI/ENVI .hdr Labelled
Files: 10SEP10191223-M2AS-052377832030_01_P003_ps_gs_bl_tc.envi
       10SEP10191223-M2AS-052377832030_01_P003_ps_gs_bl_tc.hdr
Size is 42255, 51712
Coordinate System is:
GEOGCS["WGS 84",
    DATUM["WGS_1984",
        SPHEROID["WGS 84",6378137,298.257223563,
            AUTHORITY["EPSG","7030"]],
        TOWGS84[0,0,0,0,0,0,0],
        AUTHORITY["EPSG","6326"]],
    PRIMEM["Greenwich",0,
        AUTHORITY["EPSG","8901"]],
    UNIT["degree",0.0174532925199433,
        AUTHORITY["EPSG","9108"]],
    AUTHORITY["EPSG","4326"]]
Origin = (-120.066479999999999,39.271554000000002)
Pixel Size = (0.000004500000005,-0.000004500000005)
Image Structure Metadata:
  INTERLEAVE=BAND
Corner Coordinates:
Upper Left  (-120.0664800,  39.2715540) (120d 3'59.33"W, 39d16'17.59"N)
Lower Left  (-120.0664800,  39.0388500) (120d 3'59.33"W, 39d 2'19.86"N)
Upper Right (-119.8763325,  39.2715540) (119d52'34.80"W, 39d16'17.59"N)
Lower Right (-119.8763325,  39.0388500) (119d52'34.80"W, 39d 2'19.86"N)
Center      (-119.9714062,  39.1552020) (119d58'17.06"W, 39d 9'18.73"N)
Band 1 Block=42255x1 Type=UInt16, ColorInterp=Undefined
Band 2 Block=42255x1 Type=UInt16, ColorInterp=Undefined
Band 3 Block=42255x1 Type=UInt16, ColorInterp=Undefined
I need to end up with a Byte TIF image with good color balance from this
input.  Running rgb2pct.py on this dataset just outputted a "blank" (grey)
image.  Running gdal_translate -of GTiff -ot Byte -scale [min] [max] worked
somewhat, but its near impossible to get this looking right, since the
scaling I want to do differs from band to band (e.g. if there any way to use
-scale to adjust each band separately)?  Alternatively, how would I get
rgb2pct.py working on the above image correctly?  Thanks!
--j
On Wed, Jun 8, 2011 at 4:10 PM, Nikolaos Hatzopoulos <nhatzop at gmail.com>wrote:
> why you don't try rgb2pct http://www.gdal.org/rgb2pct.html?
> --Nikos Hatzopoulos
> On Wed, Jun 8, 2011 at 2:20 PM, Jonathan Greenberg <greenberg at ucdavis.edu>wrote:
>> Folks:
>> I am using a piece of software which is relying on an older version of
>> GDAL that doesn't have the "fix" to deal with > 8 bit geotiffs (it is trying
>> to make a jpeg overlay but can't from a 16 bit image.  I think this is the
>> issue: http://trac.osgeo.org/gdal/wiki/TIFF12BitJPEG), but when I do a
>> straight convert (-ot Byte) the output image looks really washed out.  Any
>> hints for getting the best quality output from a 16 bit to to an 8 bit
>> conversion of a Geotiff?
>> --j
>> Jonathan A. Greenberg, PhD
>> Assistant Project Scientist
>> Center for Spatial Technologies and Remote Sensing (CSTARS)
>> Department of Land, Air and Water Resources
>> University of California, Davis
>> One Shields Avenue
>> Davis, CA 95616
>> Phone: 415-763-5476
>> AIM: jgrn307, MSN: jgrn307 at hotmail.com, Gchat: jgrn307
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
One Shields Avenue
Davis, CA 95616
Phone: 415-763-5476
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110608/698a77eb/attachment.html
