[gdal-dev] SDE driver: connecting to rasters never returns
Duarte Carreira
DCarreira at edia.pt
Mon Jun 13 10:38:12 EDT 2011
Hello listers.
So now that OGR connecting is solved by specifying the version name (or maybe by making a readonly connection), I'm stumbling on the same effect when connecting to a raster with gdalinfo or gdal_translate. But there is no option to specify version or readonly...
My gdalinfo/translate commands never end... they keep going with 0 cpu...
This is the same raster that I used when reporting #2063<http://trac.osgeo.org/gdal/ticket/2063>...
One example command:
gdal_translate -of vrt SDE:server,5151,database,user,pwd,user.MOSAIC_ORTO_10K_IGEOE,RASTER c:\temp\gdalteste.vrt
Anyway I can debug this?
Thanks.
Duarte
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110613/e249626e/attachment.html
