[gdal-dev] OpenJPEG2000 issues when reading blocks at a time
Cole, Derek
dcole at integrity-apps.com
Tue Jun 14 10:28:27 EDT 2011
I am afraid I won't be able to post a screenshot, or the original image that is causing this issue.
I will also note, occaisionally the image fails to load at all, and I get a dump like this:
ERROR 1: Marker is not compliant with its position
ERROR 1: opj_read_header() failed
ERROR 1: IReadBlock failed at X offset 1, Y offset 0
ERROR 1: GetBlockRef failed at X block offset 1, Y block offset 0
Segmentation Fault
Googling for those error message reveals about 2 results, and this email thread is one of them =\
From: Chaitanya kumar CH [chaitanya.ch at gmail.com]
Sent: Monday, June 13, 2011 11:13 PM
To: Cole, Derek
Cc: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] OpenJPEG2000 issues when reading blocks at a time
Derek,
Can you provide a screenshot of the displayed image. Especially the scrambled blocks.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110614/fcff3036/attachment.html
