[gdal-dev] "disformed" images in its positions
Chaitanya kumar CH chaitanya.ch at gmail.com
Wed Jun 15 04:12:23 EDT 2011
Frederick,
You can use GCPs you used to create the polynomials directly in gdal
utilities to correct the deformed images.
I assume that your current images don't have any projection info.
1. First use gdal_translate with the -gcp option to create a dataset with
your control points. You may also want to include the -a_srs option to add
the projection of your control points. [1]
2. Then use gdalwarp to correct the image. gdalwarp uses the GCPs to warp
the image. You may need to use the -geoloc option to force the use of GCPs
and the -tps option to force the thin plate spline transformer. Set an
appropriate resolution using -tr or -ts[2]
Let us know how it goes.
[1]: http://www.gdal.org/gdal_translate.html
[2]: http://www.gdal.org/gdalwarp.html
On Wed, Jun 15, 2011 at 3:29 AM, frederick keusch <
frederick.keusch at digimapas.cl> wrote:
> Hi,
> i would like to use gdalwarp to solve a problem we have. Like i am a very
> new user of gdal I don't know, if gdalwarp really can solve the problem,
> but
> I hope so. The problem that we have are a kind of "disformed" images in its
> positions. The images have several shifts in various directions. But we
> found a mathematical way to solve this problem applying a polynom with
> various parameters. But like there are too many images with the problem, we
> would like to use a program to apply that polynom to all of the images
> respectively to their coordinates.
> Our idea was to use the gdalwarp to solve this problem and apply a
> reprojection using e.g. something like this example formula giving from
> gdal...
> -t_srs '+proj=utm +zone=11 +datum=WGS84' raw_spot.tif utm11.tif
> .... and inserting the polynom in some way.
> Does somebody know, if it is posible to solve this problem with gdalwarp
> and
> if, how and where to insert the poynom?
> I appreciate your help,
> thanks a lot,
> Frederick
> http://osgeo-org.1803224.n2.nabble.com/disformed-images-in-its-positions-tp6476206p6476206.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110615/c4961e47/attachment.html
