[gdal-dev] jpeg in tiff artifacts
Brian Case
rush at winkey.org
Thu Jun 16 13:59:35 EDT 2011
matt,
jpeg is a lossy format. the nodata is ignored because those pixels are
no longer the same value as the nodata value.
You can add a mask band to the tiff but unfortunately aside from
gdalwarp and mapserver I don't think there is any other way to read it.
see http://docs.oam.osgeo.org/storage/creating.html
Brian
On Thu, 2011-06-16 at 10:20 -0700, Matt Wilkie wrote:
> Hello,
> When I convert with gdal_translate and use jpeg compression in geotiff
> format there is artifacting on the edges. It looks like nodata is being
> ignored. Is there any way to avoid this? (and still use jpeg or
> equivalent space-saving compression)
> see attached.
