[gdal-dev] Remove projection info
Tue Jun 21 07:29:18 EDT 2011
On 11-06-21 07:05 AM, Goo Creations wrote:
> Hi all,
> I'm looking for a way to remove any projection and CRS information from an
> image. I've tried:
> gdal_translate -a_srs "" in.tif out.tif
> but without any success. Does anyone know how to do this (or by using
> CreateCopy() via source code)?
Goo,
Using -co PROFILE=BASELINE will produce a TIFF file with no internal
georeferencing tags of any kind.  There might still be a .aux.xml you
could remove.
Unfortunately I don't think the -a_srs (and the SetFromUserInput() method
that underlies it) has a way of setting an empty coordinate system.  Perhaps
that should be enabled.
Best regards,
