[gdal-dev] Problem with umlauts and other special characters in shapefile attributes selected from Oracle Spatial
Georg Sedlmeir georg.sedlmeir at muenchen.de
Wed Jun 22 04:06:48 EDT 2011
Dear gdal-developers and users,
Our department (being part of the municipality of Munich) uses ogr2ogr
to retrieve data from the city administration's central Oracle Spatial
database as follows:
ogr2ogr -f "ESRI
Shapefile"/opt/uis/muc/shapes_geodatenpool/aktuell/vagrund_adr_suche_`date
+%Y_%m`.shp* -nlt POLYGON OCI:[rguuser1]/[kennwort]@serverxy.de -sql
"select * from vagrund.adr_suche"
The command works fine basically, but characters like the german umlauts
in attribute data end up as ? in the resulting .dbf files.
The character encoding used in the database is WEISO8859P15. My first
idea was to use oracle's CONVERT command right in the sql statement to
convert from WEISO8859P15 to UTF-8 but neither of them is featured in
the list of supported encodings to be found in oracle's corresponding
PL/SQL documentation.
Do you have any suggestions regarding a workaround or solution to the
problem, maybe by changing gdal configuration settings? Any help would
be much appreciated, thank you very much.
Best regards,
Georg Sedlmeir
Dipl.-Geograph
Landeshauptstadt München, Referat für Gesundheit und Umwelt
Abteilung Umweltschutz
Gesundheits- und Umweltberichterstattung (GUBE)
RGU-UW112
Bayerstr. 28a, 80335 München
Telefon: +49 - 89 - 233 - 4 75 40
Telefax: +49 - 89 - 233 - 4 77 05
E-Mail:  gube.rgu at muenchen.de
Elektronische Kommunikation mit der Landeshauptstadt München:
http://www.muenchen.de/ekomm
