[gdal-dev] JAXAPalsar 1.0 & 1.1 extended metadata reading support
Antonio Valentino
antonio.valentino at tiscali.it
Sat Jun 25 07:21:01 EDT 2011
Il 25/06/2011 12:48, Antonio Valentino ha scritto:
> Hi Rodolfo,
> can you please confirm that the data type of PALSAR Level 1.5 products
> should be GDT_UInt16 and not GDT_Int16 as in current implementation?
> If so I will file a ticket with a patch for fixing the issue.
> thanks
... here it is the patch in case you want to give it a try
ciao
> Il 17/06/2011 21:28, Rodolfo Bonnin ha scritto:
>> Hello all,
>> I'm just working with some JAXAPalsar images, and I've discovered that
>> there is no retrieval of the coordinate system metadata retrieval in
>> the current driver, the driver documentation says georeferencing is
>> only supported in level 1.5.
>> Has anyone tried to implement the feature for this lower level? I have
>> gathered some good information about how this could be done, but in
>> order to exempt myself to repeat effort, I prefer to consult the list
>> beforehand.
>> Many thanks in advance.
Antonio Valentino
Type: text/x-patch
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110625/2e8d06db/fix-palsar-level-1.5-data-type.bin
