[gdal-dev] WCS driver, GetSubdatasets (Python) returns empty list
Peter Baumann p.baumann at jacobs-university.de
Mon Jun 27 13:05:07 EDT 2011
Hi list,
on that occasion it may be noteworthy that OGC is about to publish a Request for
Comments (RFC) on the
     10-140 OGC Web Coverage Service - Earth Observation Application Profile
nicknamed EO-WCS. This specification, which has been tasked by ESA, specializes
WCS for use in remote sensing.
An open source reference implementation of EO-WCS is available with EOxServer,
see www.eoxserver.org. Among other features, it provides a tight integration
with MapServer and GDAL.
Thought this might be of interest to the list.
-Peter
On 06/26/2011 12:25 AM, Even Rouault wrote:
> Le dimanche 26 juin 2011 00:03:55, Jachym Cepicky a écrit :
>> Hi,
>> using Python, gdal 1.8.0, Ubuntu
>> I need to access some Temporal information about available WCS layer
> Jachym,
> Frank has added support for WCS temporal information in GDAL trunk just a few
> days ago. So it is not available in GDAL 1.8.0 (I've just updated the doc to
> mention that)
> With a GDAL build from trunk, gdalinfo shows this :
> Driver: WCS/OGC Web Coverage Service
> Files: time.xml
> Size is 645, 585
> Coordinate System is:
> PROJCS["GGRS87 / Greek Grid",
>      GEOGCS["GGRS87",
>          DATUM["Greek_Geodetic_Reference_System_1987",
>              SPHEROID["GRS 1980",6378137,298.257222101,
>                  AUTHORITY["EPSG","7019"]],
>              TOWGS84[-199.87,74.79,246.62,0,0,0,0],
>              AUTHORITY["EPSG","6121"]],
>          PRIMEM["Greenwich",0,
>              AUTHORITY["EPSG","8901"]],
>          UNIT["degree",0.0174532925199433,
>              AUTHORITY["EPSG","9122"]],
>          AUTHORITY["EPSG","4121"]],
>      UNIT["metre",1,
>          AUTHORITY["EPSG","9001"]],
>      PROJECTION["Transverse_Mercator"],
>      PARAMETER["latitude_of_origin",0],
>      PARAMETER["central_meridian",24],
>      PARAMETER["scale_factor",0.9996],
>      PARAMETER["false_easting",500000],
>      PARAMETER["false_northing",0],
>      AUTHORITY["EPSG","2100"],
>      AXIS["Easting",EAST],
>      AXIS["Northing",NORTH]]
> Origin = (409900.000000000000000,4503200.000000000000000)
> Pixel Size = (20.000000000000000,-20.000000000000000)
> Metadata:
>    TIME_POSITION=2010-10-17T04:00:00.000Z
> Subdatasets:
>    SUBDATASET_1_NAME=WCS_SDS:time="2010-10-17T00:00:00.000Z",time.xml
>    SUBDATASET_1_DESC=Coverage 20101012T210222_pig at time
>    SUBDATASET_2_NAME=WCS_SDS:time="2010-10-17T01:00:00.000Z",time.xml
>    SUBDATASET_2_DESC=Coverage 20101012T210222_pig at time
>    SUBDATASET_3_NAME=WCS_SDS:time="2010-10-17T02:00:00.000Z",time.xml
>    SUBDATASET_3_DESC=Coverage 20101012T210222_pig at time
>    SUBDATASET_4_NAME=WCS_SDS:time="2010-10-17T03:00:00.000Z",time.xml
>    SUBDATASET_4_DESC=Coverage 20101012T210222_pig at time
>    SUBDATASET_5_NAME=WCS_SDS:time="2010-10-17T04:00:00.000Z",time.xml
>    SUBDATASET_5_DESC=Coverage 20101012T210222_pig at time
> Corner Coordinates:
> Upper Left  (  409900.000, 4503200.000) ( 22d56' 2.07"E, 40d40'29.14"N)
> Lower Left  (  409900.000, 4491500.000) ( 22d56' 8.10"E, 40d34' 9.76"N)
> Upper Right (  422800.000, 4503200.000) ( 23d 5'11.49"E, 40d40'33.86"N)
> Lower Right (  422800.000, 4491500.000) ( 23d 5'16.66"E, 40d34'14.45"N)
> Center      (  416350.000, 4497350.000) ( 23d 0'39.58"E, 40d37'21.89"N)
> Band 1 Block=645x585 Type=Float64, ColorInterp=Undefined
> So your best luck is to checkout svn trunk and build by yourself ;-)
> Best regards,
> Even
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Dr. Peter Baumann
  - Professor of Computer Science, Jacobs University Bremen
    www.faculty.jacobs-university.de/pbaumann
    mail: p.baumann at jacobs-university.de
    tel: +49-421-200-3178, fax: +49-421-200-493178
  - Executive Director, rasdaman GmbH Bremen (HRB 26793)
    www.rasdaman.com, mail: baumann at rasdaman.com
    tel: 0800-rasdaman, fax: 0800-rasdafax, mobile: +49-173-5837882
"Si forte in alienas manus oberraverit hec peregrina epistola incertis ventis dimissa, sed Deo commendata, precamur ut ei reddatur cui soli destinata, nec preripiat quisquam non sibi parata." (mail disclaimer, AD 1083)
