[gdal-dev] datum projection info in ecw
Armin Burger armin.burger at gmx.net
Tue Jun 28 14:19:09 EDT 2011
Nicholas
I was interested about similar things a few weeks ago and got quick help
in this forum. As jean-Claude already mentioned there's a header editor
for Windows that allows you to see/edit the datum and projection info.
Jean-Claude also created a tool "ecwhed" that allows you to get and set
these parameters via the command line, at least under Linux it compiles
easily, it requires the ECW SDK.
If you create ECW's via GDAL you should use the options -co "PROJ=..."
and -co "DATUM=..." to be sure what GDAL writes to the ECW header. For
reading ECW files GDAL uses the definitions in the file "ecw_cs.wkt" (on
Unix under /usr/local/share/gdal/). There you can add your own
projections and datums or modify existing ones, eg. adding datum shift
parameters. Programs that use GDAL for raster rendering like QGIS or
ArcGis 10 can also work with these new projection definitions if you add
them to their own "ecw_cs.wkt" file, Mapserver takes the file of the
GDAL installation.
Regards
Armin
On 28/06/2011 03:09, nicholas.g.lawrence at tmr.qld.gov.au wrote:
> Hello all,
> Does anyone know where the datum and projection information is stored
> inside an ecw?
> Kind regards,
> Nicholas Lawrence*
> Senior Spatial Science Officer | Darling Downs Region / Toowoomba Office *
> Assets & Operations* Division | Department of Transport and Main Roads
> Floor 1 | Toowoomba - Phillip Street | 1-5 Phillip Street (cnr Clopton
> Street) | Toowoomba Qld 4350
> PO Box 645 | Toowoomba Qld 4350
> P: (07) 46390764 | F: (07) 46390750
> E: nicholas.g.lawrence at tmr.qld.gov.au
> W: www.tmr.qld.gov.au *
> Tomorrow's Queensland: strong, green, smart, healthy and fair –
> www.towardQ2.qld.gov.au*
> P | Please consider the environment before printing this email
> WARNING: This email (including any attachments) may contain legally
> privileged, confidential or private information and may be protected by
> copyright. You may only use it if you are the person(s) it was
> intended to be sent to and if you use it in an authorised way. No one
> is allowed to use, review, alter, transmit, disclose, distribute, print
> or copy this email without appropriate authority.
> If this email was not intended for you and was sent to you by mistake,
> please telephone or email me immediately, destroy any hardcopies of
> this email and delete it and any copies of it from your computer
> system. Any right which the sender may have under copyright law, and
> any legal privilege and confidentiality attached to this email is not
> waived or destroyed by that mistake.
> It is your responsibility to ensure that this email does not contain
> and is not affected by computer viruses, defects or interference by
> third parties or replication problems (including incompatibility with
> your computer system).
> Opinions contained in this email do not necessarily reflect the
> opinions of the Department of Transport and Main Roads,
> Maritime Safety Queensland or endorsed organisations utilising
> the same infrastructure.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
