[gdal-dev] GDAL/OGR 1.8.1 Advance Warning
Even Rouault
even.rouault at mines-paris.org
Wed Jun 29 13:45:04 EDT 2011
Le mercredi 29 juin 2011 08:18:44, Anton Korosov a écrit :
> Hi Frank!
> There is a bug in the current Envisat driver which could be fixed in 1.8.1.
> Not all bands (MDS) are read properly from the MERIS Level 2 imagery.
> Below are last lines of the output of
> gdalinfo MER_RR__2PNPDK20110502_144833_000024913102_00097_47956_7579.N1
> MDSs are numbered from 1 to 13, then 16 and 19. And in the file MDSs
> 14-15 and 17-18 also exist.
> I'm not sure if that's the proper place to report this bug but I just
> follow your invitation.
Did you search in GDAL Trac if such a bug has been already reported ? If there
is none related, you might want to create one with all necessary information
(mainly the description of your email + a link to / attachment of a publicly
available dataset that shows the issue).
> All the best!
> Anton
> Band 1 Block=1121x1 Type=UInt16, ColorInterp=Undefined
> Description = Norm. rho_surf - MDS(1)
> Band 2 Block=1121x1 Type=UInt16, ColorInterp=Undefined
> Description = Norm. rho_surf - MDS(2)
> Band 3 Block=1121x1 Type=UInt16, ColorInterp=Undefined
> Description = Norm. rho_surf - MDS(3)
> Band 4 Block=1121x1 Type=UInt16, ColorInterp=Undefined
> Description = Norm. rho_surf - MDS(4)
> Band 5 Block=1121x1 Type=UInt16, ColorInterp=Undefined
> Description = Norm. rho_surf - MDS(5)
> Band 6 Block=1121x1 Type=UInt16, ColorInterp=Undefined
> Description = Norm. rho_surf - MDS(6)
> Band 7 Block=1121x1 Type=UInt16, ColorInterp=Undefined
> Description = Norm. rho_surf - MDS(7)
> Band 8 Block=1121x1 Type=UInt16, ColorInterp=Undefined
> Description = Norm. rho_surf - MDS(8)
> Band 9 Block=1121x1 Type=UInt16, ColorInterp=Undefined
> Description = Norm. rho_surf - MDS(9)
> Band 10 Block=1121x1 Type=UInt16, ColorInterp=Undefined
> Description = Norm. rho_surf - MDS(10)
> Band 11 Block=1121x1 Type=UInt16, ColorInterp=Undefined
> Description = Norm. rho_surf - MDS(11)
> Band 12 Block=1121x1 Type=UInt16, ColorInterp=Undefined
> Description = Norm. rho_surf - MDS(12)
> Band 13 Block=1121x1 Type=UInt16, ColorInterp=Undefined
> Description = Norm. rho_surf - MDS(13)
> Band 14 Block=1121x1 Type=UInt16, ColorInterp=Undefined
> Description = YS, SPM, Rect. Rho- MDS(16)
> Band 15 Block=1121x1 Type=UInt16, ColorInterp=Undefined
> Description = Alpha, OPT - MDS(19)
> On 27/06/2011 14:31, Frank Warmerdam wrote:
> > Folks,
> > I would like to prepare a 1.8.1 release candidate in the next couple
> > days.
> > Developers are encouraged to address any bug fixes they would like
> > promptly.
> > Is there anything folks feel strongly needs to be addressed in 1.8.1 that
> > has not yet made it into the 1.8 branch?
> > Best regards,
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
