[gdal-dev] GDAL/OGR 1.8.1 Advance Warning
Even Rouault even.rouault at mines-paris.org
Wed Jun 29 13:53:05 EDT 2011
Le mardi 28 juin 2011 21:32:01, Armin Burger a écrit :
> Frank
> a functionality that I would find useful in combination with clients
> like ArcGIS or Erdas are the Erdas overviews in *.rrd files. When
> creating overviews with gdaladdo using the "--config USE_RRD YES"
> option, aux files instead of rrd files are created. They are not fully
> recognized by ArcGis/Erdas, depending on the image format.
I'm afraid I know very little of the subtleties of Erdas overviews, but I see
that the HFA_USE_RRD config option can also be set to YES and produces a .rrd
file. Perhaps this is was you are looking for.  See
http://gdal.org/frmt_hfa.html . I've found also a past thread where this is
somehow discussed : http://www.mail-archive.com/gdal-
dev at lists.osgeo.org/msg00129.html
