[gdal-dev] Precision Mystery (FGDB)
Peter Baumann p.baumann at jacobs-university.de
Thu Jun 30 14:52:56 EDT 2011
to retain the 3rd dimension, maybe better use WGS84-3D, EPSG:4329 ?
-Peter
On 06/30/2011 08:45 PM, Paul Ramsey wrote:
> In running a round trip from PostGIS>FGDB>PostGIS for a simple table:
> 3dgeom=# select st_asewkt(g) from points ;
>         st_asewkt
>   SRID=4326;POINT(1 2 3)
>   SRID=4326;POINT(2 3 4)
>   SRID=4326;POINT(3 4 5)
> When I get to FGDB, I've lost my third dimension (still trying to
> figure that out)
> [pramsey at localhost postgis2fgdb]$ ../gdal-svn/gdal/apps/ogrinfo -al ~/3dgeom.gdb
> INFO: Open of `/home/pramsey/3dgeom.gdb'
>        using driver `FileGDB' successful.
> Layer name: points
> Geometry: 3D Point
> Feature Count: 3
> Layer SRS WKT:
> GEOGCS["WGS 84",
>      DATUM["WGS_1984",
>          SPHEROID["WGS 84",6378137,298.257223563,
>              AUTHORITY["EPSG","7030"]],
>          AUTHORITY["EPSG","6326"]],
>      PRIMEM["Greenwich",0,
>          AUTHORITY["EPSG","8901"]],
>      UNIT["degree",0.0174532925199433,
>          AUTHORITY["EPSG","9122"]],
>      AUTHORITY["EPSG","4326"]]
> FID Column = OBJECTID
> Geometry Column = g
> OGRFeature(points):1
>    POINT (1.0 2.0 0.0)
> OGRFeature(points):2
>    POINT (2.0 3.0 0.0)
> OGRFeature(points):3
>    POINT (3.0 4.0 0.0)
> But even odder, when I go back to PostGIS, I've got slight coordinate drift.
> 3dgeom2=# select st_asewkt(g) from points ;
>                                  st_asewkt
>   SRID=4326;POINT(1.00000000000005 2.00000000000001 1.04446235346063e-305)
>   SRID=4326;POINT(2.00000000000005 3.00000000000001 1.04446235346063e-305)
>   SRID=4326;POINT(3.00000000000005 4.00000000000001 1.04446235346063e-305)
> (3 rows)
> I just turned on statement logging and watched both the export and the
> import to PostGIS and in both cases the database is sending and
> receiving the canonical form (hex ewkb) there is no text
> representation step. This seems frightfully odd. Any suggestions on
> debugging steps?
> Paul
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Dr. Peter Baumann
  - Professor of Computer Science, Jacobs University Bremen
    www.faculty.jacobs-university.de/pbaumann
    mail: p.baumann at jacobs-university.de
    tel: +49-421-200-3178, fax: +49-421-200-493178
  - Executive Director, rasdaman GmbH Bremen (HRB 26793)
    www.rasdaman.com, mail: baumann at rasdaman.com
    tel: 0800-rasdaman, fax: 0800-rasdafax, mobile: +49-173-5837882
"Si forte in alienas manus oberraverit hec peregrina epistola incertis ventis dimissa, sed Deo commendata, precamur ut ei reddatur cui soli destinata, nec preripiat quisquam non sibi parata." (mail disclaimer, AD 1083)
