[gdal-dev] Windows builds and wildcard usage for gdaltindex &
gdalbuildvrt
Armin Burger
armin.burger at gmx.net
Tue Mar 1 13:00:32 EST 2011
Tamas, Frank
thanks a lot for the quick response to this issue (I just noticed
today...). I will download the new Windows binaries.
Armin
On 24/02/2011 22:40, Tamas Szekeres wrote:
> Hi Armin,
> I've just added wildcard support to the builds at
> http://vbkto.dyndns.org/sdk/ according to Frank's suggestion. The
> corresponding binaries should be available with the next daily builds.
> Best regards,
> Tamas
> 2011/2/24 Armin Burger <armin.burger at gmx.net <mailto:armin.burger at gmx.net>>
> Hi all
> I wanted to use a more recent Windows build than the latest FW Tools
> which are a bit old now. I used the binaries from
> http://vbkto.dyndns.org/sdk/PackageList.aspx?file=release-1310-gdal-1-8-0-mapserver-5-6-6.zip
> All works fine, just the usage of wildcards in tools like gdaltindex
> or gdalbuildvrt does not work any more. If I run eg
> gdaltindex tileindex.shp *.tif
> I just get the error that the file "*.tif" could not be found. Same
> happens for gdalbuildvrt.exe. So the wildcard resolution seems not
> to work any more (it still did work in the last FWTools 2.4.7). For
> gdaltindex I can use a "for" loop command because it adds every tif
> to the same shape, but I don't think this workaround works for the
> gdalbuildvrt.
> On Linux builds the wildcards usage still works fine with GDAL 1.8.
> Any ideas if this will be fixed for Windows?
> Armin
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
