[gdal-dev] Conversion from WGS84 to NAD83(EPSG:26912 - NAD83 / UTMzone 12N )
Eli Adam EAdam at co.lincoln.or.us
Tue Mar 1 18:03:20 EST 2011
Sumit,
     Looking at EPSG:26912 on spatial reference, http://spatialreference.org/ref/epsg/26912/ and your longitude coordinates (74-76 East, no less) makes it questionable if 26912 is an appropriate projection.  That projection looks valid for western Mexico, and midwestern US/CA.  You data looks to be roughly in Asia.
     I think that error says that it is not in a valid area of the target projection.
Bests, Eli
>>> On 3/1/2011 at 2:28 PM, in message <1299018481319-6078961.post at n2.nabble.com>,
Delirious <sumitpandey87 at gmail.com> wrote:
> I am trying to convert a file in WGS format to Conversion from WGS84 to
> NAD83(EPSG:26912 - NAD83 / UTM zone 12N ),
> comman line input is
> C:\Program Files (x86)\FWTools2.4.7>gdalwarp -t_srs EPSG:26912
> G:\TestData\dem43m.tif G:\TestData\opt.tif
> ERROR 1: Too many points (441 out of 441) failed to transform,
> unable to compute output bounds.
> I am giving above stated error.
> gdalinfo of the input file is given below
> Size is 1201, 1201
> Coordinate System is:
> GEOGCS["WGS 84",
>     DATUM["WGS_1984",
>         SPHEROID["WGS 84",6378137,298.257223563,
>             AUTHORITY["EPSG","7030"]],
>         AUTHORITY["EPSG","6326"]],
>     PRIMEM["Greenwich",0],
>     UNIT["degree",0.0174532925199433],
>     AUTHORITY["EPSG","4326"]]
> Origin = (74.999583333333334,36.000416666666666)
> Pixel Size = (0.000833333333333,-0.000833333333333)
> Metadata:
>   TIFFTAG_SOFTWARE=ERDAS IMAGINE
>   TIFFTAG_XRESOLUTION=1
>   TIFFTAG_YRESOLUTION=1
>   TIFFTAG_RESOLUTIONUNIT=1 (unitless)
>   AREA_OR_POINT=Area
> Image Structure Metadata:
>   INTERLEAVE=BAND
> Corner Coordinates:
> Upper Left  (  74.9995833,  36.0004167) ( 74d59'58.50"E, 36d 0'1.50"N)
> Lower Left  (  74.9995833,  34.9995833) ( 74d59'58.50"E, 34d59'58.50"N)
> Upper Right (  76.0004167,  36.0004167) ( 76d 0'1.50"E, 36d 0'1.50"N)
> Lower Right (  76.0004167,  34.9995833) ( 76d 0'1.50"E, 34d59'58.50"N)
> Center      (  75.5000000,  35.5000000) ( 75d30'0.00"E, 35d30'0.00"N)
> Band 1 Block=64x64 Type=Int16, ColorInterp=Gray
> Am i doing anything wrong?
> Thanks
> Sumit Pandey
