[gdal-dev] Polygon
Chaitanya kumar CH
chaitanya.ch at gmail.com
Thu Mar 3 10:24:39 EST 2011
Alexandre,
Can you send your code as a .cpp file as an attachment?
Also, I think you should change the line
Buffer[size+1]='\0';
to
Buffer[size]='\0';
On Thu, Mar 3, 2011 at 6:34 PM, Alexandre Leclerc <a.leclerc at valabre.com>wrote:
> Hello I try to draw a polygon from shapefile on geoconcept.
> But the points that I get are corrupted.
> Strangely a shapefile with no prj, and one ring in WGS84 works.
> Here I try with a prj with lambert 2 extend projection.
> The shapefile contains 2 rings.
> See my code below.
> ifstream Prj;
> Prj.open(PrjPath,ios::in);
> if(Prj.is_open())
> /*-----------read of PRJ--------------*/
> Prj.seekg(0,
> ios::end);
> int size =
> Prj.tellg();
> Prj.seekg(0,ios::beg);
> char * Buffer = new char[size+1];
> Prj.read(Buffer,size);
> OGRSpatialReference oSRS, oSRS2;
> OGRCoordinateTransformation *poCT;
> oSRS.importFromESRI(&Buffer);
> oSRS2.SetGeogCS( "My geographic coordinate system",
> "WGS_1984",
> "My WGS84 Spheroid",
> SRS_WGS84_SEMIMAJOR,
> SRS_WGS84_INVFLATTENING,
> "Greenwich", 0.0,
> "degree",
> atoi(SRS_UA_DEGREE_CONV));
> poCT =
> OGRCreateCoordinateTransformation(&oSRS,&oSRS2);
> if((poCT == NULL)||(poPoly->transform(poCT)!= OGRERR_NONE))
> //Convert lambert 2 to WGS84
> MessageBox(NULL,"Erreur,
> Réessayez","Erreur",MB_ICONERROR);
> PRJ = true;
> return;
> Prj.close();
> int nparts = poPoly->getNumInteriorRings();
> if(nparts==0)
> nparts = 1;
> for(int
> n=0;n<nparts;n++) //for
> npart…
> OGRLinearRing *poRing;
> if(poPoly->getNumInteriorRings()>0)
> //if I understand correctly, through the function
> poRing =
> poPoly->getInteriorRing(n); //
> OGRGeometryFactory::organizePolygons() of
> else
> //SHPReadOGRObject,
> all the outer rings are converted in inner rings
> poRing =
> poPoly->getExteriorRing(); //so if there is
> more rings than 0, there is many interior rings
> //else getInteriorRing(n) should be give the N rings
> //but the function gives one ring with one point which as an incorrect value
> const LPXTNPOINT3D tabPoints = new
> XTNPOINT3D[poRing->getNumPoints()]; //Tab of points for draw ring
> for(i=0;i<poRing->getNumPoints();i++)
> // Loop To Assign Points good projection
> XTNPROJECTIONINFO xtnProjectionInfo =
> XtnStartMapProjection(xtnMapID); // Creating a
> projection for the coordinates
> LPXTNPROJECTION lpxtnProjection = new
> XTNPROJECTION;
> lpxtnProjection->prLongitude =
> poRing->getX(i)*3.1415926535/180;
> //Longitude point conversion in Projected
> lpxtnProjection->prLatitude =
> poRing->getY(i)*3.1415926535/180;
> //Latitude--------------------------------------
> XtnProjection_Do(xtnProjectionInfo,
> lpxtnProjection); //Projection
> conversion
> XtnProjection_Destroy(xtnProjectionInfo);
> tabPoints[i].X
> =((long)((double)(lpxtnProjection->prX * 100.0 + 1.0))) / 100; //Conversion
> long
> tabPoints[i].Y
> =((long)((double)(lpxtnProjection->prY * 100.0 + 1.0))) / 100;
> tabPoints[i].Z = 0 ;
> XtnGeom_SetPoints(MaForme,n,poRing->getNumPoints(),tabPoints);
> // Insertion Points in the figure
> So, can you help me to fix my problem please ?
> Sincerely.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110303/a584d6e1/attachment-0001.html
