[gdal-dev] gdal and hdf-eos
Matt Funk
mafunk at nmsu.edu
Fri Mar 4 12:31:45 EST 2011
Hi Chaitanya,
no, i didn't build it myself. I simply downloaded the self-installing
package for gdal found at: http://www.lfd.uci.edu/~gohlke/pythonlibs/
<http://www.lfd.uci.edu/%7Egohlke/pythonlibs/>
I am a little unfamiliar still with building stuff on windows, so i am
not sure whether it's worth trying to build gdal and the python bindings
from scratch or simply use h4toh5 called from the script.
thanks
matt
On 3/3/2011 9:30 PM, Chaitanya kumar CH wrote:
> Matt,
> Did you build GDAL yourself? HDF4 format is not compiled by default.
> You can check if this by running the command "gdalinfo --formats". See
> if HDF4 is in the output.
> http://www.gdal.org/frmt_hdf4.html
> On Fri, Mar 4, 2011 at 6:03 AM, Matt Funk <mafunk at nmsu.edu
> <mailto:mafunk at nmsu.edu>> wrote:
> Hi,
> i am using python/gdal. I am trying to open a MODIS satellite file
> from the Terra satellite (which is hdf4-eos format). Doing:
> ds = gdal.Open(file)
> drivertype=ds.GetDriver().LongName
> returns
> ERROR 4:
> `C:/tmp/SrcData/2010Data/MODISData/MOD03/MOD03.A2010002.1810.005.2010258062733.hdf'
> not recognised as a supported file format.
> Is this file format not supported?
> thanks
> matt
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
> Best regards,
> Chaitanya kumar CH.
> /tʃaɪθənjə/ /kʊmɑr/
> +91-9494447584
> 17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110304/6c659a5e/attachment.html
