[gdal-dev] gdal and hdf-eos
Nikolaos Hatzopoulos
nhatzop at gmail.com
Fri Mar 4 14:57:36 EST 2011
you are not compiling things from source?
On Fri, Mar 4, 2011 at 10:57 AM, Chaitanya kumar CH
<chaitanya.ch at gmail.com>wrote:
> GDAL's HDF4 driver is built on top of NCSA HDF library.
> On Sat, Mar 5, 2011 at 12:20 AM, Nikolaos Hatzopoulos <nhatzop at gmail.com>wrote:
>> what extra libraries requires hdf4? i think only requires szip zlib and
>> jpeg
>> On Fri, Mar 4, 2011 at 10:03 AM, Chaitanya kumar CH <chaitanya.ch@
>> gmail.com> wrote:
>>> Matt,
>>> If there is a work around it's better to avoid building. HDF4 requires
>>> some extra libraries. They are probably missing.
>>> On Fri, Mar 4, 2011 at 11:01 PM, Matt Funk <mafunk at nmsu.edu> wrote:
>>>> Hi Chaitanya,
>>>> no, i didn't build it myself. I simply downloaded the self-installing
>>>> package for gdal found at: http://www.lfd.uci.edu/~gohlke/pythonlibs/
>>>> I am a little unfamiliar still with building stuff on windows, so i am
>>>> not sure whether it's worth trying to build gdal and the python bindings
>>>> from scratch or simply use h4toh5 called from the script.
>>>> thanks
>>>> matt
>>>> On 3/3/2011 9:30 PM, Chaitanya kumar CH wrote:
>>>> Matt,
>>>> Did you build GDAL yourself? HDF4 format is not compiled by default. You
>>>> can check if this by running the command "gdalinfo --formats". See if HDF4
>>>> is in the output.
>>>> http://www.gdal.org/frmt_hdf4.html
>>>> On Fri, Mar 4, 2011 at 6:03 AM, Matt Funk <mafunk at nmsu.edu> wrote:
>>>>> Hi,
>>>>> i am using python/gdal. I am trying to open a MODIS satellite file from
>>>>> the Terra satellite (which is hdf4-eos format). Doing:
>>>>> ds = gdal.Open(file)
>>>>> drivertype=ds.GetDriver().LongName
>>>>> returns
>>>>> ERROR 4:
>>>>> `C:/tmp/SrcData/2010Data/MODISData/MOD03/MOD03.A2010002.1810.005.2010258062733.hdf'
>>>>> not recognised as a supported file format.
>>>>> Is this file format not supported?
>>>>> thanks
>>>>> matt
>>>>> _______________________________________________
>>>>> gdal-dev mailing list
>>>>> gdal-dev at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>>>> Best regards,
>>>> Chaitanya kumar CH.
>>>> /tʃaɪθənjə/ /kʊmɑr/
>>>> +91-9494447584
>>>> 17.2416N 80.1426E
>>> Best regards,
>>> Chaitanya kumar CH.
>>> /tʃaɪθənjə/ /kʊmɑr/
>>> +91-9494447584
>>> 17.2416N 80.1426E
> Best regards,
> Chaitanya kumar CH.
> /tʃaɪθənjə/ /kʊmɑr/
> +91-9494447584
> 17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110304/03d6fe23/attachment.html
