[gdal-dev] ogr2ogr vector central meridian change,
vector offset issue.
Even Rouault
even.rouault at mines-paris.org
Sun Mar 6 17:47:11 EST 2011
Ilia,
Try adding -wrapdateline to your command line. The wrapdateline option
instructs ogr2ogr to split geometries crossing the dateline meridian. I've
just tested it successfully on one of those datasets.
> Hello,
> We are trying to re-project the coral reef dataset via ogr2ogr for
> the dataset to fit the bluemarble projection. The coral reef is a vector
> shape dataset and it is using the Lambert Cylindrical Equal Area at -160
> central meridian. Once we re-project we are getting lines connecting the
> shapes that are cutoff at the edges from -180 to 180. Is that a bug ?
> or are we doing something wrong?
> You can see the offset issue here
> http://dukodestudio.com/client_room/coralreefs/coralReefData-offsetlineissu
> Here is the location of the dataset
> http://www.wri.org/publication/reefs-at-risk-revisited#datasets
> Our command is as follows:
> ogr2ogr -s_srs '+proj=cea +lon_0=-160 +lat_ts=0 +x_0=0 +y_0=0' -t_srs
> EPSG:4326 reefPoly28.shp reef_500_poly.shp
> We did try to use the "-spat -180 -90 180 90" flag with the above commnd
> but without success.
> Thanks, ik.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
